hi guys,well im stuck on code p0172,i change both o2 because the car has 188,000 miles on it and the code come back,i check the vacuum hoses and found some elbows broken,replace elbows and clear codes,still present,so i check the air filter,is ok but i found in the case where the air filter go has like a door,you know the one is for winter time or summer time,this door is close in winter time position,i mean the car only take hot air from muffler,so i switch to the other position and i surprise,the car run a lot better so i think bingo thats it,clear codes again and guess what,same code again,so im a little lost in that code,im afraid to buy the maf sensor and then the same code again,i spend 400 bucks on both o2 sensors,this parts is not cheap and i dont want throw my money away,so im be happy with some advise or is someone have the same problem,please i need do va emission and i pretty sure not pass like that,thanks for your help.
car is a volvo 960 1997,2.9l sedan
