Electric System In And Out
1 reading
1.8K views 1 reply 2 participants last post by  danielm85948
#1 ·
I first thought it was just a cold thing, but now it's not starting at all in a warmed garaged. The electrical system seems to go in and out, makes this crazy clicking kind of noise, and eventually will make the dashboard lights go entirely, the message system saying then the breaks have failed, pull over, etc., On a cold morning it won't crank, and when it finally does it will immediately shut off. Once I finally overcome it, the electical system clicks and clicks, and eventually will lose daashboard lights and functions... no turn signal, nothing.
If I can get driving for 15 minutes or so without the electrical interference happening, it will run fine like normal and I can restart the car fine the rest of the day... but the next morning (especially if cold) I go through the process again.
Now it's just not cranking at all...it's clicking, but it sounds like a louder clicking than a dead battery... it's like the electrical system is overriding it entirely and won't let me get the car started at all.
Other symptoms: when I get the key near the ignition (not putting it in) the clicking of the electric system starts. Interior lights flicker, etc.
Today it won't start.
#2 ·
QUOTE (shroudbrother @ Mar 9 2015, 11:36 AM) <{POST_SNAPBACK}>I first thought it was just a cold thing, but now it's not starting at all in a warmed garaged. The electrical system seems to go in and out, makes this crazy clicking kind of noise, and eventually will make the dashboard lights go entirely, the message system saying then the breaks have failed, pull over, etc., On a cold morning it won't crank, and when it finally does it will immediately shut off. Once I finally overcome it, the electical system clicks and clicks, and eventually will lose daashboard lights and functions... no turn signal, nothing.
charge up your battery ,then check it is holding the charge .and check the output of your alternator ,should be 14.3 volts.
