QUOTE (grendel1960 @ Sep 10 2020, 05:04 PM)
<{POST_SNAPBACK}>A charged lead acid battery should read 12.8 volts, by the time it is at 12v it will only have about 40% charge and any further discharge will damage the battery, other battery types will be different, as your is the hybrid version, i am not familiar with the battery technology used, but if its not holding charge, then either the charging system has an issue or the battery does.
Agreed...
As far as I can tell the PHEV has a crankshaft motor/generator on the petrol engine which operates on the 300V ish hybrid battery. This battery is charged when you plug the car into the AC power or operate a manual control that makes the petrol engine run. The electric traction is quite separate from the IC engine and works the back axle, while the IC engine works only front.
The large (95Ah) 12V battery probably does everything that the non hybrid version does .. computers, box, heaters, lights etc but does not directly start the engine. There are draws of 10 to 20A without lights and heaters. I am guessing that the electric powered Aircon for cabin (and hybrid battery?) runs off the 300V battery due to the necessary high power level.
There is an inverter responsible for controlling the 12V charge levels from the 300V battery. It can operate when plugged into the AC power, and when turned on in any engine mode.
Mine (almost new) decided not to charge at a vital time leading to a 'temporary transmission error' apparently (according to garage) caused by a drop in 12V voltage detected as I tried to accelerate from battery only to combined mode. This error was latched until the computers went to sleep so as to reboot (takes 45-60 minutes off and locked). It had the effect of preventing petrol engine start. It seems at this point the inverter had 'forgotten' that it needed to charge the 12V.
So I am now monitoring charge status by voltage to discover if this issue manifests again. This morning the battery just got to 14.01 after trying the various modes and then switching 'off' which has various multi minute timeouts, and in this case continued charging allowing this typical end of charge level before I exited.
On a previous day after an 8 mile battery trip I was surprised to find 12.36V, with the load in the region of 5 to 10A which suggests a rather low charge state, and none of the usual methods would induce any charging. After a couple of hours it was plugged into the AC mains charger and this time started charge, initially at at least 10A over the loads, this seemed 'correct' and I supposed the car had slept, been rebooted and corrected the dubious flag that had prevented charging when most needed.
I have asked my dealer to investigate the possibility of a software bug, meantime I will monitor regularly.
David Osborne
