Selling my OEM roof rails that were installed on a 2018 XC60. These are USED, not new, in very good condition 8.75-9.00 out of 10
Compatible Model: For Volvo XC90 2016-2022. Please check your model to be sure they fit your year.
Stock Image. In box, used just during the ski season for the last few years.
Possible fit on XC70
Below is description from where I purchased for $310.00
A high-quality load carrier for safe and secure transport of roof loads.
The aerodynamically shaped wing profile has been optimized to give minimal air resistance and wind noise, which makes the car journey more comfortable.
The load carrier makes it quick and easy to install Volvo's roof boxes, bicycle holders and cradles for sports equipment.
Together with the integrated torque wrench, it can be easily adjusted for correct fastening, which increases safety and security.
It is easy to install and remove.
Facts and advantages
  • Attractive Volvo design.
  • Aerodynamic wing profile with T-track.
  • All load carrier accessories fit:
    • Ski/Snowboard carrier
    • Bicycle holder
    • Space boxes
    • Canoe/kayak carrier
  • Some load carrier accessories must be adapted to fit the T-track.
  • Volvo branded.
  • Thoroughly tested both in the laboratory and on the test track.
  • Ergonomic adjustment with integrated torque wrench and lock.
  • Lock included (including four keys).
  • "City Crash" tested.1
Technical data
Material:Aluminum with protective cover in TPE
Color:Black with aluminum profile
Accessory weight:5.2 kg (11 lbs)
Load width:980 mm
Maximum roof load:75 kg ((220 lbs) including
