I forgot to ask about starting problem. Will it turn over? If so, when you first turn the key to position II can you hear the fuel pump turn on? If not, then your Fuel pump module (FPM) is probably wet. The FPM is located down under by the fuel tank on the right side. Disasemble, dry it out, check for corrosion inside and clean it. Make sure the little drain hole is clear, spray down with electrical contact cleaner and reinstall.
