For all those who own late model Volvo (V70, XC, S80, etc). If you are under warranty, make a request to your dealer or Volvo North America to fix or clean your ETM. Sooner or later, your car will die with no gas pedal response. Your engine message will say "Check Engine" or "Performance Reduced". COMPLAIN and FIX IT NOW!
This is very dangerous because you can be driving and all of sudden your engine stalls with no response to your gas pedal. You can stop the car and turn off the engine for one minute and "walla" nothing had happened because "performance Reduced" message is gone. If they check the message under VADIS engine diagnotic, it will clearly say ETM failure. Volvo dealer wants $1200 or more to replace the ETM. $400 for cleaning it. I noticed several posts had this problem and you probably paid out of your pocket for this or other things thinking that it might fix the problem. Sooner or later you will have to replace that ETM. Better do it while you are under warranty.
I'm out of warranty and I should have been notified of this problem earlier based on the fact that Volvo North America knew about this problem because the class action lawsuit was filed 3 years earlier when I was under warranty. They refuse to fix and decides to make their decision based on "good will" if you brought your vehicle for maintenance. Since I'm out of warranty, they're telling me that I have to pay, which I refuse to for a car that is in mid-life, when they know that this is a major engine throttle design defect.
Here are the links to
http://www.fazmiclaw.com/Volvo.html
I have attached the lawsuit file (PDF)
Some of you mechanics on board have been helpful in your advise but this is totally raping those who are less knowledgeable about cars. It could MAF sensors, PVC valve, but when anyone on this board says "Performance Reduced", it is clearly ETM failure and Volvo wouldn't pay for it unless you complained about it and have it fixed under "good will" by the dealer. This is FRAUD, and hence the lawsuit.
Volvo for Life!???? You got to be kidding! Someone could get killed when your gas pedal does not respond when everyone on the highway is whizzing by at 70mph, or if you are trying to cross a street, you could get your side smacked if your engine stalls!
BAVMOTOR
BAVMOTOR
