Hey can anyone tell me where my a/c drain hose is located on my car? When I turn my a/c on it sounds like a running waterfall inside the dash? I think the hose is stopped up and not allowing the water to drain out.
Thanks for the help!
Michael McClung
It is located under the radio behind the dash.To access it pull down on the carpet on the side of the dash.Then remove the side cover plastic cover under the carpet.There is a tab at the back of the panel the cover goes over.Then slide the cover towards the back of the car and it will come out.Then look in and you will see the drain in the middle of the dash.A rubber hose going into the floor.Try to blow some air into it and then let it drain.Make sure you have something for it to drain into or stick it back on quick.
You can access it from either side it is the same form either side.
I always do it from the passenger side more room.
