hi all,
does anyone know how to turn off alarm and immobiliser without remote,
i got someone to have a look at it and they disconnected the battery, now when i connect it back up the alarm goes off and the immobiliser kicks in so i cant do anything with the car,
someone out there must be able to help,do i just disconnect the alarm so immobiliser works off normal key??
i hope someone out there can help
with thanks
brandon
Have you tried using your key to lock then unlock your car that should overide the alarm system.If not try to disconnect the battery again and connect it.Then lock and unlock the car before you open the door.If not that remove the lower dash panel on the drivers side.Look for a box with a bunch of relays in it.Look for on the says anti theft or something like that and try to remove it and see if the car runs. GOOD LUCK.
QUOTE (slayerz @ Nov 9 2004, 09:00 PM) <{POST_SNAPBACK}>just to let you know i got alarm sorted out,i pulled 15amp fuse that was below steering wheel
talk about a joke though......
thanks for advice
Hey, I have the same problem you did, cannot find this 15amp fuse under the steering wheel, could you let me know exactly where I should be looking please.
Thanks in advance for your help.
Hi there,
I also had the same issue with alarm and immobiliser on my 940 Wentworth, from viewing the posts I just removed the 15amp fuse from directly under the steering column, this appears to have completely disabled the alarm, immobiliser and horn however does anyone know if the removal of the fuse cuts anything else out?
Cheers
Pete
Hi! i know this post is waaay old. but if you guy's are still here. Could you please tell me what alarm you dissabled with just removing a fuse? you can PM me if you don't want to tell potential thiefe's on the forum.
the reason i want to know is that if i have the same alarm, then it's going in the trash, and in with another one.
