Should the rubber insert inside the top motor mount be solid and the bracket rigid if you try to shake it? Mine appears to have splits in the insert and I can wiggle the bracket side to side. Broken Mount?
On my S60 at least, it wasnt very solid, and gave alot. I just replaced it Sunday with a poly bushing. I was amazed at how easy it was to put slits in the original, but was still a real pain to get out.
From what ive read these things go bad pretty often. IF its falling apart, u should replace it. Its probably just a matter of time until it falls apart.
QUOTE(topdwn @ Sep 4 2005, 08:21 PM)Should the rubber insert inside the top motor mount be solid and the bracket rigid if you try to shake it? Mine appears to have splits in the insert and I can wiggle the bracket side to side. Broken Mount?
[snapback]14737[/snapback]​
Yes it is bad.
