Looking for the steps of taking off the ETM so i can clean it?
Looks like it would be easiest to take off the Intake manifold to remove the ETM?
Most of the time it is easier to remove it with the intake in place.
Is it turbo?
About 100 of them.
First remove the turbo hose and pipe to the throttle body.The clamps are a 7mm socket to loosen.The one on the throttle body is pretty hard to get to.Some people remove the cooling fan to help with space.But I don't.
Then you will need to remove the bracket from the starter to the engine.It has 2 10mm nuts on the starter and 1 12mm bolt going into the block.Then remove the 4 10mm screws holding the throttle body to the intake.Unplug the throttle body and remove.
NOTE: Be careful sliding it out some cars have a cover on the positive wire on the starter and some don't.On the ones that don't I tie a rag around the wires and watch carefully as I remove.
