The First Of Many I'm Sure
1.1K views 2 replies 3 participants last post by  funnyguy44444
#1 ·
Hi there everyone, just picked up a 92 240 for my daughter. I'm sure this is the first of many times I'll come around looking for help
Here's my first question. I don't have an owners manual for the car so I don't know what some of the lights on the dash are about and I haven't found anything else yet to help so here goes. There is an arrow that lights up on the far right of the cluster of warning lights, sometimes it's lit up, sometimes it's not, what is it? Next to that one going to the left is one that looks like a light bulb perhaps; again it's on and off from time to time, and I don't know what it's trying to tell me. Any help would be appreciated, there are several other issues with it, but I figured that I'd start with these ones, and work my way through them. thanks again
Eric
#2 ·
The up arrow should be lit up when you 'dis-engage' the Overdrive. That is supposed to be for when you are towing a trailer or driving in a very hilly area. It isn't used by about %95 of the people, but it causes problem. It isn't uncommon for the relay for it and/or the Solenoid for it to go bad. If you start the car, the light should be off. When you press the little button on the side of the shifter handle, it should light up. If anything different then that is happening post back and I or someone else will walk you through it.
I would have to look on my 240 to see what the other light is, but I am betting (without looking mind you) that it is the 'bulb-failure' light. These cars have a ciruit that checks the resisitance for the lighting circuits. When a bulb is out (or a wrong bulb is installed) the light will light up on the dash. IIRC, 240's do have a bit of a weak spot with the circuit board for the tail/brake/reverse lights. Another comon problem is that people use a standard American replacememnnt bulb (1156 or 1157) in place of the European light bulb. When the car sees the different resistence, it thinks a bulb is out. In my opinion, the best way to get around these two issues at the same time is to go to a good auto store and see if they that the European bulbs in stock. If so, take out the tail light circuit board, bring it into the store and buy all the bulbs needed for both sides at once. This way, you are sure that the bulbs are right, you aren't messing around with the circuit board all the time and when you are done, it should cost less then $20 for peace of mind.
Should you care to diagnose the problem before buying all of those bulbs, just turn on all of the lights and walk around the car. Make sure all are working. If you'd like, you could turn on one thing at a time until the 'bulb failure' light comes on, then you'd know what circuit your problem is on.
I hope that gives you an idea of where to start. And, of course, Welcome aboard!
Again, if you replace all the bulbs and there is still a problem, post back.
#3 · (Edited by Moderator)
The light bulb light (orange on mine) is indeed the bulb failure light. As he said they are really temperamental. I would just have someone stand outside the car and check to make sure all the lights are working properly headlights, brights, tail, brake, turn, parking and reverse) If one is out replace it. I don't think it's that important to get the special european bulbs the only thing that they will do differently is not make that temperamental circuit go off. Once you replace any non working bulbs or if you don't have any don't even worry about that stupid light. If it bugs you that it is on just take out the bulb for the warning light.
