Replaced operating motor and fuse is OK. Any other areas I may have missed ?
Thanks, I did not check the switch. Did replace the motor and fuse. I will check the switch out, and have the wind blowing through my hair yet.are you getting power to the motor, are the switches working
I had a chance to look a schematic of the electrical system and there is a relay also which may be the culprit.Thanks, I did not check the switch. Did replace the motor and fuse. I will check the switch out, and have the wind blowing through my hair yet.
