1 - 9 of 9 Posts
Does anyone know how to change the switch for the sunroof? Is it diffuicult to do?
My sunroof will not go back only the back lifts, i think its the switch is there a way to test the switch?
Richard
It is kind of a pain to change.Keep playing with it there might just be some dirt in it.
If not then you can replace it but will take you some time to do.
Is threr i way that i can test to find out if the problem is the switch before i gor thru the work of changing it. The sun reaR lifts but won't retract
Not really without pulling it all apart.
Unless you had the vadis program and the VCT2000 to connect to the car and read output signals.
So how do you pull the switch apart? Do you have to take the whole assembly out in one piece (which includes the lights and mirror)?
Pretty much yes then when it is all apart then the switch itself will come out of the assembly.
The colored plastic around the switch itself will pull down.
Then I forget it might just pull down from there.I think there is tabs under the plastic cover under by the sunroof switch.
1 - 9 of 9 Posts
