my S90 antenna starts to pull up but stops half way, idont get a good signal at some points and it is frustrating when your trying to listen to something on the radio. i manually pull it up, but then the next time i start my car and radio, it doesn't pull up all the way.
The mast is most likely bent.If you replace it you will be fine.
If its not bent, it just needs to be lubbed. I had a car with a power antenna that had the same issue once in a while. Either rub it down with grease, or carefully spray it with WD-40. Always worked for me
