Help
Ive an odd problem with the volvo if i start the car with the clutch pedal pressed the cruise control lights up but when i lift the pedal it drops out and an engine service req message comes up.
Im told there is a switch for the cruise control attached to the pedal ive found a long white switch which has two strips of carbon in it it looks ok and works fine on an ohm meter is there another one somewhere else that ive missed any help would be apprechiated
many thanks
I had this problem when mine was still under warranty. I believe it was a case of replacing one of the modules mounted on the brake servo though. Not 100% sure though.
