Hi, I own an S60 2.4T SE Geartronic. Recently i noticed that the climet control is not working at its best.
After 30 - 40 minutes of operating beautifly, the temp just drops to a deep freeze mode... and the only way to warm the car is to set the climet control to MAX heat.
any other mark, which is not the maximum heat, will send a freezing cold blast of air throgh the vents,.
Both controls are set to 22 degrees.
did any one knows about such problem ? or even better - how to fix it ?
Raviv
2 things the evap temp sensor goes bad sometimes and will mess things up.Also there might be a software issue.Check with the dealer and see if there is an upgrade avalible for your car.
long time since i logged in... still the problem was resolved.
The temprature fan of the aircondition unit had some dust in it. The dealer just cleaned it and the fan got loose again.
The problem was that sometimes the fan got stuck and produce heat - making the unit belive that the car is much hotter that it was...
very simple solution, and the dealer did not charge me for it.
Raviv
