Thanks for that mate it is much appreciated. Im still a little unsure about doin the pod filter thing without changing other thinhs aswell. Emmision light has come on when i changed it a couple of days ago until i changed it back..Do you think that the ECU will adjust to it?
I know it wont give it a massive amount of a power increase if at all but i want to start givin the thing a bit of a tweek since i had a quick bash in a EVO 3 the other day. It only had 155kw and mine has 147kw but shit it had some torque.
Did you leave the mass flow sensor attached to the car when you put the new filter on?
If you don't the car will run like crap.
As long as you keep all of the electronics in the proper spots then you will be fine.The compter will adjust itself.
