FRONT PASSENGER DOOR ON 98 V 70 WILL OPEN FROM THE OUTSIDE BUT NOT THE INSIDE. WHAT SHOULD I LOOK FOR AND WHAT IS THE EASIEST WAY TO GET THE DOOR PANEL OFF. THANKS FOR YOUR HELP
Remove the trim ring around the door handle.Then remove the cover in the grab handle to close the door.Then remove the t-25 screw.Then the rest of the door panel is held in with clips.
I would look at the inside handle cable.They are known to break.There is a tab that locks the cable inside the handle and the tab breaks.You might be able to use a wire tie to hold the cable in.
