In the bottom of the filter housing under the filter is a spring steel ring. On the bottom of that is attached a rubber (or similar) disc which seals a drain hole in the bottom of the housing. Purpose is to maintain a full housing so there is. oil immediately on startup. When the filter is raised up the spring raises the seal up off the hole and the oil drains into the crankcase, so the oil change is not as messy.... Common problem that the rubber disc detaches from the ring and the hole then drains constantly, so you don't have oil immediately on startup. You must have the rubber disc stuck to the hole would be my guess.
