Hi to you all,
just wondering if any of you could help me, i have recently brought a late shape v70 t5 1000, miler goes really well, anyway the abs/ t/control & eminisions warning lights keep comming on, if i disconnect the battery, switch on the ign to drain any static electricty out of the pcb, and then re-connect the battery, all is well for about one to two weeks, then they start comming on again.(i just think that maybe the pcb or whatever is building up static, over a period of time, then sending out the wrong info. I'ts driving me nuts, i now it can't be anything much, as everything works fine, when the lights are out. (sorry gone on a bit there)
thanks anyway, Colin ([email protected])
Welcome
. Please post under related forum to get a better response. New member area forum is for introductory purpose only.
When the lights are on you need to have the codes pulled.The lights come on because there is a fault in the system.
The ABS module is most likely bad for the ABS light.
The check engine light can be about 100 different things.
