Hello
I have volvo 850 1193 , I purchased a new keyless remote switch but it is not working , does it need some kind of programing ? before the purchase I geve my
VIN # TO THE DEALER - so that he coold mazeh the part. is there any more to do ? the dealer is in U.S and I am in the mid-east.
any any one help
EMAD
hi ya try this it worked on mine and most other cars,put the ignition on so the dash lights up sit in the car close the door and hold the lock button on the pad keep it held for a few secs or until the car locks, turn of igition get out and try see wot happens.let me know thanks
Most of the time to program you will need to turn the ignition on and off 5 times on the 5th time leave the key on and then press a button on the remote. Then turn the key off and remove it out of the ignition and see if the remote works.
Tip: make sure all doors and the hood are closed or it won't go into program mode.Also if you have a LED on the dash when it goes into program mode the light should light up.
RECEIVER PROGRAMMING
GUARD ALARM I
1) Ensure alarm is deactivated. Close all doors, hood, and
trunk. Turn ignition on. Press function button on status panel until
status LED and indicator LED are lit. Release function button. Using
status panel function button, advance to unoccupied key code location
I, II or III. An occupied location is indicated by a flashing LED. An
unoccupied location is indicated by a steadily lit LED. If a code is
programmed into an occupied location, the old code is erased.
2) Select one of 3 locations. Send a code signal within 10
seconds using remote control. Alarm will acknowledge an approved code
with brief flashes of status and indicator LED's before reverting to
standard mode.
GUARD ALARM II
1) Ensure all doors, hood, and trunk are closed. Turn
ignition on and off at least 5 times in 10 seconds. Indicator LED
should start to flash. Leave ignition on. Once indicator LED starts
flashing, first remote control must be programmed within 15 seconds.
2) Press one button on one remote control. Programming is
acknowledged by indicator LED lighting for about 2 seconds. Indicator
LED will then start flashing for 10 seconds. Program other remote
control within 10 seconds while indicator LED is flashing. Turn
ignition off. Test remote controls.
