1 - 12 of 12 Posts
Hi
My T4 has a bit of juddering at 4000rpm when accelerating hard in 3rd (manual gearbox) gear. Not noticeble in 1st or 2nd gear. If I drive through the problem the car seems to lost it power. New coil leads and plugs have been fitted.
The problem can be worse some days than others.
I would appreciate any help on the matter
Yes both coils and the fly leads for cylinders 1 & 2. Also i have checked the condition of plugs lately and all are in good condition and burning evenly.
But because they look good doesn't mean they are good how old are they?
They only have a life of 30,000 miles.
I have exactly the same problem on my 1998 V40 T4. I have been chasing this fault for 2 years now. I have replaced both coils and leads and it has actually cut out on me. I am starting to think that it is fuel starvation / pressure drop to the fuel rail.
I have noticed that it is worse if you are low on fuel and going uphill it has actually ground to a halt. After waiting 10 minutes it will start up again and be fine for another few months.
I removed my fuel pump from the tank and found that it was covered in black dirt - including the whole of the tank inside. As a quick fix I cleaned up the filter on the end of the pump and put it back - hey presto no missfires for a few months.
I now intend to clean the whole of the tank out properly.
PAULW when I asked Volvo about the problem they suggested a new fuel pump was the cure or the coils, unfortunantly a pump cost a lot of money £300. So you could be on the right track. Anybody does your car have a return hose from the fuel inlet manifold? mine does not yet the fuel pump has a return hose and the pressure side hose goes directly to the vacuum valve on the manifold. I can see a return pipe coming out of the manifold but no hose is attached (it does not leak petrol). Is there a better source for info on the Turbo models than the Haynes manual which has very little on the turbos.
There are other manuals (and CDs) available but I am not sure how good they are - just did a Google search & they're out there.
What petrol are you using? The T4 is designed for & runs best on 98 RON petrol. Even Super Unleaded is only 97 RON - maybe you need to try several tankfuls of Shell Optimax (98 RON) to clean your injectors etc. up & to adjust the ECU via the various sensors on the engine. Might need to run as many as 300 litres through the system to clean injectors/valves etc. thoroughly - the ECU will adjust timing etc. much more quickly than that.
Hope you find a cost-effective solution!
Discussion Starter · #9 ·
I use the top quality fuels and have used fuel system cleaners which do seem to make a short term improvement.
Managed to get hold of a vacuum/pressure testing device and have found that the turbo wastegate valve will not hold a pressure. This would seem to be the fault with the car. I am guessing that a faulty wastegate will cause overboost of the air pressure and I believe the car has a built in safety feature that cuts the fuel ( same as the way the traction controll works ) in this overboost condition, can anyone confirm this?
Can someone tell me where I can get a new wastegate from? I suspect Volvo is quite expensive.
I'm confused as to why the fault is only apparent in 3rd gear though.
Have you checked that your car has had any/all Volvo software updates?
Tech is your man for questions about turbos - if anyone can sort it out, he will.
On this forum, you're never.....
Yes I beleive they have a cutoff for overboost.
Im not sure where to get one aftermarket.
1 - 12 of 12 Posts
