1 - 11 of 11 Posts
I hear a noise (like a high speed fan) when I reach about 60K/hr from the front. It goes to a higher pitch when the car reaches about 80-90K/hr. I have not noticed any abnormal wear on my wheels. Is this because the front bearing are gone? they say replace including the hub?
Would appreciate comments from those that have similar experience.
It is either a bad tire or the front wheel bearing.You can try to rotate the tires and see if the noise is still there.If it is then there is a bad bearing.Replacing the bearing does require replacing the hub it comes as one peice.
QUOTE(The Doctor @ May 19 2005, 02:48 PM)I would replace the technician
if he can't tell you what is causing the noise after putting car on hoist and doing test drive he don't know his stuff
[snapback]8193[/snapback]​
AGREED!!!!!!!!!
1 - 11 of 11 Posts
