1 - 8 of 8 Posts
Having a problem with a 1998 Volvo V70 wagon -- at highway speed, the "hesitates, stumbles, or stutters" a few times -- as if it suddenly isn't getting enough fuel. No code is showing up in the computer. I have had 4 mechanics look at the car & try several fixes (e.g., new coil) and even had the 60K Mile Service redone. There was some oil in the spark plug housing at one point, and this was supposedly fixed. I have even tried putting in Fuel Injector Cleaner. Any ideas would be much appreciated
Checked Evap Value (emission control) because a missing gas cap can cause this code to activate in computer
Checked for bad O2 Sensor
Coil Arching (fires the plugs)? Tried new coil
Checked Spark Plugs Bad? Did complete 60K mile service
Later, Volvo found oil in housing for spark plugs; fixed ring / seal & replaced plugs and wires again
Checked battery ground wire
Put Fuel Injector Cleaner in gas tank
Any suggestions on other areas to check? Thanks.
There could be a bad spot in the throttle position sensor.
Could be a bad mass flow sensor.
Could be a bad engine speed sensor.
Could be many other things as well.
Mine does the same thing, until I clean the throttle body with CARB cleaner. It eventually acts up again, but is a good temp fix (about 3 months), in my opinion.
I have been told that early V70's have bad (and should be recalled) throttle bodies. I think that most likely is your problem too, but I am by no means an expert.
QUOTE(Radio Flyer @ Nov 18 2005, 10:46 PM)Mine does the same thing, until I clean the throttle body with CARB cleaner. It eventually acts up again, but is a good temp fix (about 3 months), in my opinion.
[snapback]18895[/snapback]​
The 1998's don't have the electronic throttle body's. They are a little different to DIAG.
1 - 8 of 8 Posts
