Final question for now. Not normally this vocal, but new car so want to sort asap any issues that come up. Final issue is that while going up and down gears is fine, and no noise or play when changing gear, when the car is in gear you can actually wiggle the stick almost as if it was still in neutral. Dealer says this is normal for this car ... but it can't be can it? Can anyone else wiggle the gear stick while it's still in gear?
I suppose one answer is don't try and wiggle the gear stick when in gear ;-) but if there is an issue with bushes nor linkage then I'd rather get it sorted by dealer asap.
Dave
Most of the time there is a little slack in the shifter.There are cables from the shifter to the transmission.In the ends of the cables are rubber bushings that have some give to them.
