Evaperator Replacement:
First thing you have to do is disconnect the battery.
Next you will need to remove all the freon.
Next start off by removing the wiper arms.There is a 13mm nut per arm.You may need to remove a black cover to get to the nut.
Then remove the 4 Torxes 25 screws holding the plastic cover under the the wiper arms.You will have to also remove the 2 clamps holding the rubber hoses to the plastic cover.Lift up on the front of the cover then slide it towards the front of the car to remove it.
Then under there is Either 4 torxes 30 screws or 10mm screws that hold the dash to the body of the car.Be very careful removing and tightening the screws for the dash.The dash tabs could break and then will need to be repaired or the dash will need to be replaced.Also just pull up on the pollen filter case if it has one.If not just remove the ring that is there.
Next remove the 2 heater core line that go into the firewall.Push the plastic clips on both sides of the hose in then pull on the hose to remove.
Then remove the 2 T-15 or t-20 screws going through the metal cover on the heater core where you just removed the 2 hoses from.
Next remove the A/C lines from the evaperator on the outside of the car.But before you do that remove the allen screw that holds the metal line to the body of the car behind the headlight on the right side of the car.It is towards the front of the car on the other side of the freon port.Then when you remove the A/C lines they should be able to slide since you removed the allen screw.
That should be all for under the hood for now.
Going to the inside of the car you will need:T-25 socket or bit with a screwdriver,A long T-30 socket,18mm socket with extension and ratchet,wire cutters,T-15,T-20,10mm ,12mm,13mm,1/4 drive socket.
First start off by removing the center console.If it is a 850 remove the front cubby by reoving the 2 T-25 screws then under the cover is 2 T-15 screws remove them.Unplug the black and grey plugs in the hole by the 2 T-15 screws.Then lift up the armrest and remove the black cover and remove the 2 8mm or 10mm screws.The early 850's may have T-25 screws.
The S70 remove the shifter boot cover bye pulling it towards the drivers seat with the arm rest up.Then remove the cover in the cover under the arm rest.Remove the 2 screws in there.
Unplug the 2 plugs behind the cover for the E-brake.Lift the back of the center console up first and work it out.
Next remove the radio by pushing in the little tabs on the side of the radio then they will pop out and then pull them to release the tabs all the way.Remove and unplug the radio.
The next step will depend whether you have ECC (Electronic climate control)or MCC(manual climate control)
If you have ecc then you car reach through the hole for the radio and push the climate control module from the back.Be careful put a rag on your arm.Sometimes it is stubborn and when it releases it will cut your arm.
If you have MCC then remove all 3 of the control knobs.Then under the 2 outer knobs is 2 T-25 screws.Remove them then push the outside cover out from the back and unplug the wiring.On the sides you will see one Phillips screw on each side remove them.You are done here for now.
Next remove the air bag from the steering wheel.Turn the steering wheel so that the top is to one side.There is a hole in the back of the steering wheel.Insert a long T-30 and remove the screws for the airbag.Always remove and tighten the right side screw for the air bag first.If not then the horn might not work.
Next take the little T-20 screw stored in the steering wheel.That will get screwed into the hole on top of where the bolt for the steering wheel is.It will hold the Contact reel from unrolling.
Note: Break the bolt for the steering wheel loose before installing the small screw.
Remove the bolt holding the steering wheel in.It is a 18mm head bolt.Then lift the steering wheel off.
Next remove the steering column covers.On the S70 pull up on the top one and remove it.Then loosen and remove the T-25 screws in the bottom cover.The screws go from the bottom going up.
The 850 you will have to remove 2 T-15 screws in the front part of the cover.You will need it to be long to reach the screws.That will remove the top cover.Note be careful removing the T-15 screws.Hold down on the top cover while removing then or the tabs might break off the top cover.
Then remove the 2 T-25 screws and remove the lower cover.
Next remove the turn signal switch and the wiper switch.They are held on by 2 T-25 screws each.Next remove the SRS contact reel.Note:Be very careful the plastic is very brittle.
There is 3 screws total holding it in.Then unplug it and remove it all the way.
Next remove the lower dash panel on the left side of the car.Then look up under the dash and you should see a long red plug.It should have a tab to pull to release it.Pull it and release it.That is the main plug for the dash.
Next on the 850 you will have to remove the metal knee bolsters.There is 13mm nuts holding it in.Note:Or you can wait till you remove the dash.It is easier to remove them once the dash is out.
Pull back the cover at the bottom of the dash by the door.The sill cover that runs all the way back.Pull it off by the dash.You will see a screw holding the bottom of the dash.remove the 10mm screw.
Then go to the other side and remove the glove box assembly.Remove the T-25 screws folding it in.On the 850's unhook the glove box support arms by inserting a small screw driver in the hole.Then remove the insert.Next remove the lower dash cover on that side as well.
Also unplug the passenger side Air bag.You will see the plug.Look for an orange wrapped wire and follow to the plug.Then pull back on the sill cover again and remove the 10mm screw on that side as well.
The dash should be ready to come out.Make sure you have someone help you remove it.
You will need to leave the key out of the ignition.To get the car out of park.Look on the right side of the shifter.There is a soleniod you will need to push the soleniod back and push the button on the shifter and pull out of part.
Remove the dash.If it is turbo you will also have to unplug the line for the boost guage if the car has one.Also be careful some cars have an extra plug you will have to unplug while removing the dash.Watch while removing.
Set the dash off to the side in a safe place.
Once the dash is out of the way then remove the knee bolsters if you chose to leave them till the dash was out.
Then pull and remove the 2 black air pipes that go to the white A/C box.Then remove the wiring for the blower motor,resistor and maybe the relay if you have one.Also unlock the plastic guide holding the wiring to the case.
Cut the wire ties where the wires go across the front of the case.Let them hang for now.
On the 98 S70 and the 850 look over by the gas pedal and you will see a diaphram and a rod for the cruise contol.Undo the rod from the gas pedal.
Then remove the 4 12mm bolts holding the case to the body of the car.Lift up on the case a little then pull it towards you.
Note:On the 99 and 2000 S70 you will have to remove the gas pedal and the pedal mount from the body of the car.That will allow room for the heater core lines to pull back from the firewall.
When the case is loose pull it out some and turn the box towards the seat.Then you will see the recirc door motor located on the top of the box.Remove it by removing the 3 T-15 screws.
Then remove the rest of the T-15 screws around the smaller part of the box by where the motor was attached.There is 2 clips on the back of the box that have to come off and 1 clip under where the recirc motor was.
Once all the screws are out you can remove the upper part of the cover over the Evaperator.
Replace the evaperator.Make sure you transfer the rubber seal from the pipes to the new one.
Install the cover and everything else.When you stick the box back in make sure the heater core connection and the A/C drain are back where they belong.If the drain is not connected it will leak water into the car and flood the floor board.
ALSO leave the plastic cover on the evap pipes while installing the box back in where it belongs.Also spray some lube on the rubber grommet where the pipes go through.It will make it easier to go in.
Put everything back together in reverse order.
Once everything else in the car is together then if you decide replace the dryer.
Then connect all the pipes and put the system on Vaccum for about 1HR.
Then charge the system.
I think that is everything.I migth have forgotten some small things.
If any quiestions feel free to ask.
Sorry I don't have any pictures if I find any I will put them in the post.
Hope this helps!!!!
Thanks Tech, that is a fantastic procedure.
For those who want to do this, follow EVERY STEP as listed. I added one step: remove the front seats. Undo the 4 bolts and all connectors, and flop them backwards out of the way. I have a wagon so I took the rear seat bottoms out, folded down the seatbacks, and set them there. With my bad back, this prevented a LOT of squirming around.
I did mine without issue and took the time to clean the heck out of everything. The front carpets come out really easy with the rest of the stuff disassembled so I cleaned them too.
I will start a new thread about the HVAC vents now not working...
Here are some pics, not indexed...I took them to document where stuff was. Hope they help. http://scirocco.dhs.org/cheapassron/volvo/Evap/
Thanks again Tech, you saved me about $1000.
Ron
Ted' Volvo Knuckle Busterhttp://us.f13.yahoofs.com/bc/45e73b17m72ffbffc/bc/volvo+repair/How+to+seperate+connector.jpg?bf9ClaIBjJXvYW1f
While on my way to the evaporator I came across this electrical connect. It is all that needs to come apart So I can remove the dash. How does it unplug. The one in the instructions is different. It is in my 1995 850 GLT.
See Picture.
Thanks for the great instructions and help.
My thanks to Tech. I just finished the replacement of both the A/C evaporator and the heater core
in my 98 V70. The instructions were great and this is one of the bigger jobs that I have done. By paying careful
attention to the steps and not rushing, I was able to complete the whole job in a weekend- and it sure is great
to once again have A/C and windows that will not fog over in a rainstorm. The following link also had some great
pictures to refer to.
http://www.woodjoiner.com/volvo/VolvoEvapReplace.pdf
