I am thinking about buying an electrical impact wrench to replace timing belts since I don't have strength to remove the crankshaft pulley bolt by hands. The processes are well explained at an internet site. Is a 240 lb-ft torque impact wrench enough to unlock the crankshaft pulley bolt?
Do I have to remove the crankshaft pulley bolt (or, simply replace by removing a small cover located just below the pulley? Is it worth to replace camshaft and crankshaft seals if no oil leaks? Any helps?
