Occasionally, after starting my car, the turn signals and headlights will not function.(The headlights are set to come on automatically.) Turing the ignition off and restarting usually fixes the problem, but it can happen later. Have any of you experienced this and what do you suggest to correct it?
The electrical part of the ignition switch is bad and will need to be replaced.
If you wiggle the key switch when it is running is should make the lights come on when it is running or make them turn off.
