QUOTE(Tech @ Jan 13 2005, 08:16 PM)Sorry to hear about that you can try to lube where it goes into the door good and it might quiet it a little.
[snapback]2271[/snapback]
I had this problem, the weld on the door retainer is prone to fail and basically you need to buy a new part at a cost of 20GBP. If your fitting it yourself you will need to take the door panel off, remove the old part (3 bolts), then the fun starts. When I did mine I spend 2 hours trying to fit the new part, just because Volvo didn't made the hole in the door (between door and wing/fendor) the same size as the bar. It's just a case of trial and error, and a good supply of Coffee. My advice would to watch carefully then angle of the bar when you remove the old part. Good luck
