It seems the drivers side window SW has decided to pack it in, was just wondering if I have to take the door panel off to get at the SW or is it removable on its own, I have a feeling the SW unit is compatible w/ other models so it will be easier to find a spare/replacement. Any advice woudl be great!
Cheers
Oz
You can remove the switch without removing the door panel.
You can use a small hook tool and hook behind the back part of the front switches and then pull up and the switch should come out without a problem.
The drivers door switch(master switch) for the C70 is a switch for only the C70.
You will have to find one for the C70.It is special because of the all windows up or down part of the switch and also the child lock for the rear windows.
