1 - 9 of 9 Posts
Hi All,
In the past 2 month, I have run out of coolant three times - in fact I had to refill with water only today. What could be causing the problem? I have not noticed anything unusual, no overheating, etc?
Thanks for your help.
You need to have someone pressure test the system to find the leak.
Thanks for the advice - I will ask the Volvo dealer "pressure test the system to find the leak".
I find that sometimes they are clueless unless you ask them to do specific tests/fixes.
Hope this is not a duplicate
But we had this problem when our car was relatively new approx 20k miles. The car would suck down a little water but not much, about a pint per month.
This was enough to cut on the low coolant light and was a bit annoying.
After several tries at the dealer we finally had them change the Head gasket. The car now has 50k miles with no problems.
Discussion Starter · #8 ·
The problem just kept getting worse and in the past month I found myself filling up with water after every 1000km or so - it was the radiator leaking:-(
1 - 9 of 9 Posts
