Has anyone else had this problem? After much frustration, the key finally came out of the ignition. The problem was on the automatic shifter. The button on the back of the automatic shifter that I depressed to put the car in park did not pop back out. It was stuck and after much playing around with the shifter it popped back out and the key was able to come out of the ignition.
Is this a serious problem or can I put a little wd40 around the automatic shifter where I depress the shifter?
Help!
If it is giving you too much problem, and heartache, consider aftermarket options.
