1 - 1 of 1 Posts
the procedure for doing so is remove the trim in your boot then remove the cover plate for your lift pump, then remove all the rubber hoses from the sender unit then remove the locking ring now hand in the hole to remove the wiring 12 inches away from the plate is a grommet in the spare wheel well push that in, now look at the wiring it goes up to a black plug on the filler down pipe push that plug through the grommet hole ande remove the wiring out of the hole for the cover plate ,now remove the locking ring. Then pull up the sender unit up and to the right care needed due to the fuel so remove the battery wires just in case.
1 - 1 of 1 Posts
