QUOTE(05gent099 @ Jan 20 2005, 11:55 AM)When I insert key in the ignition and turn on key to first position, radio turns on, but I can't turn on key to the second to start the engine. I think something happened with the ignition lock. Do I need to replace ignition lock and if yes, where I can find the part number or what could be done? Thanks,
[snapback]2433[/snapback]
If you can update us on if you were able to fix this starting/ignition issue. And if you were how did you fix it. I'm having the same problem and it makes no sense. My mechanic can't figure it out either. Any help would be much appreciated. Thanks..
