I'm trying to replace the bulb under the gear position indicator. I found a description of a similar procedure on the volvospeed website but it was for an s70. It seems to be exactly the same except for the fact that the console on a c70 extends all the way into the rear seat. I can't seem to separate them to get the main console to swing up out of the way. Are there any little tricks for a c70 console?
Some just pull up and some you have to reach under and push a button to release.
If it is the pull up type then you have to pull pertty hard.
Just want to say thanks to Tech for the advice. Was able to take care of the job in about 45 mins, knowing the right procedure.
