I'd like to eliminate the annoying TPMS warning light in my instrument cluster. Is there a bulb behind the panel that lights it up, that I can remove, if I manage to pull out the cluster ? Aside from black tape over it, any way to solve this problem ? Thanks for any suggestions !
Super Moderator
the issue may be the sender units inside the tyres, these are I believe battery powered so over time the batteries expire and the warning comes up. they should be replaced when tyres are replaced to avoid this.
As always it could be functioning correctly and warning you of low pressure in a tyre, so that would need to be checked too.
the best fix is to remove the cause of the light being on in the first place, so I hope I have given some pointers on possible causes.
