QUOTE(Tech @ Mar 2 2005, 04:58 PM)Either 1 of 2 things are happening.1 the heater core is leaking. 2. the A/C drain is clogged and draining in the car.Does it smell lika anti freeze?If not go on your passenger side on the side of the dash.Pull back the carpet from the front of the dash to the back.On the side where your left leg would be if you are sitting in the pass. seat.Then you will see a black panel behind the carpet.Feel towards the back of the dash and push the panel towards the pass. door then slide the panel backwards then remove it.Once that is done you will see a funny looking hose that goes into the floor.That is the drain for the A/C.The best way to get it unclogged is to blow some air into it then quick hook it back up and let it drain.
[snapback]4390[/snapback]
Thanks for this, If it is the core (cos i'm not sure what anti freeze smells like) what should I do? It does sound like the drain though being as the footwell gets wet.
I'll try and let you know.
