Hello,
I have a 1999 S-80 T6 and I am getting the brake fault stop ASAP message after changing my Brake booster. I thought that it was the actual abs module, however, after sending my unit out to be repaired, it turns out that there is nothing wrong with it. This leaves me to think it is the brake booster. Does anyone know if the sensor on the end of the brake booster will cause a failure, and if so, can I change the sensor on the new brake booster, with the old one which worked fine, or so I think?
Thanks,
Joe
Thanks,
Joe
