Hi All,
Another newbie here, with a few questions if that's ok?
I have a 1993, 940 Auto. Wentworth Estate, with the 2 litre (petrol) turbo engine and 166,000 miles.
1). I have a major oil leak which appears to be coming from the rear of the engine, but I cannot pinpoint the source. It seems to be underneath, near the bellhousing. Any ideas?
2). The drivers side heated seat does not work (although the passenger side does), is there a fuse that controls this, or a relay somewhere?
3). I have had one or two moments over the last month or so, where the car stalls for no apparent reason, but will start if I leave it for an hour or so. After leaving for a day, its ok again. It first happened after I put it through a car wash, after a period of being off road and needing a clean! Is there a chance that moisture gets into the ignition system, although the dizzy cap is way back at the back of the engine block?
4). I notice that upon starting, the engine turns over very slowly, but always starts first time, (except when experiencing problems as in previous question). Would a change of battery help here, I think it's about 5 years old? It was suggested the diesel battery would be a good buy.
Thanks for any help, much appreciated.
