Hey again everyone, well here is a small problem that I just encountered. Put a new a/c Blower Motor in my 94 850, and now it seems that when I turn the switch to high (4) it cuts off all together. 1,2,3 settings work great, but nothing at 4. I mean the entire blower motor stops. So does anyone have any ideas what might be happening? Could it be the resistor? And if it is how do I change it out. Hey thanks for the other info on unplugging my A/C drain, worked great and now everything is flowing great.
Thanks,
Mike
Mine has four speeds.
You need to check the wiring.Fan speed 1,2,3 go throught the resistor.Fan speed 4 is full 12 Volts for high fan speed.
You need to check the wiring from the switch to the fan motor.
Hey Volvo people, well I figured out my problem about my blower motor not working on hi (4), the fuse was blown.
Much cheaper than taking it to my mechanic.
Mike
Just the fuse?
Well good for you!
