In the last few days, the transmission will not shift into 4th, at least when cold. So far, after driving for some time, it shifts and then everything works like normal. The transmission fluid is clear and full, the shift cable is not too tight. My hope is that this is the overdrive solenoid going bad, and not something worse. Has anyone else had this problem, or is there an easy way to test it?
