QUOTE(Tech @ Dec 17 2004, 10:53 AM)Did you buy it new.It should have come with instructions.I will see if I can find anything fo you.
[snapback]1734[/snapback]​
Hi tech
It was bought from a breakers yard and sent bye post.
i never saw it being removed.
i have the 2 brackets but can't work out how they fit.
Is it the type that you have to drill 4 holes in the trunk?Or is it the type that just clamps on the trunk?If it just clamps on it should be easy to just place it and tighten the srews.
http://www.ipdusa.com/productscat.aspx?Cat...=232&RootID=629
Follow they the link and it kind of shows what it looks like on the car.Not really a good picture but might help.
QUOTE(Tech @ Dec 18 2004, 06:58 AM)Is it the type that you have to drill 4 holes in the trunk?Or is it the type that just clamps on the trunk?If it just clamps on it should be easy to just place it and tighten the srews.
[snapback]1755[/snapback]​
Thanks didn't really help looking for diagram that shows where brackets actually
fit thanks anyway.
Try to position the spoiler where you want it and tighten the clamps and it should be fine.Where it fits on the trunk there should be double sided sticky tape is it still on there?If it is test fit first then pull the plastic off to expose the tape then install.
