QUOTE(Tech @ Feb 20 2005, 11:49 PM)Try cleaning the throttle body good and see if it helps.
[snapback]3711[/snapback]
Thanks for the tip,just had the body off and gave it a very good clean and cleaned the cannister vac stubs but made no difference.
It's very strange,when you coast along on over run the revs hold on about 2 seconds and then its just like a switch is turned off and you can feel the car then start to slow. If you are behind someone it's very scary because it's like you havenot released the throttle.
I have checked to make sure the throttle is closing(it is) and have checked for fault codes (none).
Only thing I have noticed is that the problem is not there untill car starts to warm up.HELP.
