Hi I have a 1992 850 GLT (Japan new and exported to New Zealand) - the airbag SRS self test light has come on as a fault. The guy I bought the car off had a quote from a dealer that said a new airbag control unit was required. This fault is apparently a very rare part failure on 850 - other dealers in NZ have not sold one such unit as a replacement since 1992! Heat such as direct sun on the centre console has been suggested as possible one reason for the damage.
I disconnected the battery for 24 hours and the fault has not self cleared.
I have been looking around the globe for a second hand unit one without much luck - apparently the early 850's (1991 - 1992 & probably not the USA model which was first sold 1993?) did not have many interchangeable parts whereas the later 850's had a number of interchangable parts such as the airbag control unit for the period 1993 -1997.
The part numbers are Volvo 3515884 and Bosch 0 285 001 035. Bosch say that the unit was not made after 2000 and there were no supercessions.
Does anyone have any ideas for this problem? - I also got a part number of 0 285 001 041 coming back from the USA - this may be the 1993 unit that may or may not be interchangeable with the 1992 850 unit.
Thanks & cheers
zim
Thanks & cheers
zim
