Hello,
Problem started with "lambda" light on, and lots of engine stutter/rough running..
Error codes:
First i thought Crank sensor replacement would fix it, yeah cable routing was and is ok. Cleared the codes and light disappeared, but still running on the rough side at idle and below 2000rpm.
Next i changed cam pos. sensor, but lo and behold lambda light back and cam sensor code+ engine runned like crap(before RPM sensor replacement). Replaced the old cam sensor back and again code/light gone??
Sparkplugs, distriputor cab and rotator are couple months old, sparkcables and coil unit are old but i tested every spark cable and spark is present.
Dont know anymore what to do next, maybe ill change spark cables and coil. Check sparkplugs are they ok..
Error codes:
3-2-4 | Camshaft position sensor signal erratic |
3-1-4 | Camshft position sensor signal missing or defective |
