QUOTE (azvolvo @ Oct 14 2012, 09:40 PM) <{POST_SNAPBACK}>hi everyone
I have a 67 122S I am trying to work on the rear brakes
I can't get the drum off the back left tire
looks like I have disc brakes up front, drums in the rear
a coworker has been helping me , and he has tools, like the pullers etc.
but we can not get the drum off......
any tips, etc. ?
thanks in advance
Jim
your brakes are stuck on, handbrake off ,now hit the disc all round, with a rubber mallet , now you may need to renew the piston inside or try to fix it if you know how.
thanks Danielm
I tried and the drum is still stuck
this might be a dumb question, but are the lug bolts and drum that I am trying to remove a single unit, or does the drum come off, leaving the bolts behind?
QUOTE (azvolvo @ Oct 15 2012, 08:10 PM) <{POST_SNAPBACK}>thanks Danielm
thanks,
Jim
there should be one small screw holding your drum on to the hub check you have removed that.you remove the drum ,only ,the hub you remove by removing the nut for the wheel bearing.
Related Threads
Volvo Owners Forum
165.2K posts
110.6K members
Since 2004
