Hello all, more brake noise problems.
My 91 240 occasionally makes pulsating brake noise at low speed. It happens cold or hot. I Looked at all sets, with the wheels off and the friction material is good. Rotors are near new, (4 K )
Spinning ( I use the term spin here pretty loosely, because the brakes have a little drag) the rotors by hand doesn't show any noticable warp.
I removed the pads from the wheel that appears to be the offender, cleaned and lubed the slide pins. Still get the noise.
What else?
Hi Tech,
The pads were clean on the brake that I dismantled, but I will look closer on the week-end.
I will post findings.
Hello again,
I checked the rotors for grease , they are clean.
My shocks have a little fluid loss, but their action is still good. (The car still rides better than our chevy).
I suspect the caliper's pistons are hanging up.
The noise I get is low speed only, and seems to be in rythym with the rotation of the wheels. Annoying as _ell.
Any thoughts?
That annoying intermittent brake noise eventually turned into an embarassing screech that came and went. I removed the back rotors and found the source, a broken spring on the emergency brake shoe.
Now I can love my Volvo again.
