Hi I have a broken lens on my 2002 XC70 headlight ,and have been told you need the whole assembly ,because it's sealed . I received a new assembly from OEM ,for $314. vs $340 at dealer , but access is a problem . There are two bolts on top ( easy) + 3 bolts on the bottom which are behind the top of the bumper , any tips on access and removal /installation . The dealer wants to charge Labor $120 .+ to do it . Any help would be appreciated .
gbh
You will need to loosen the bumper cover.You will need to drill out the rivets in the wheel well that go into the bumper cover.There is also a screw there that you will need to loosen.It is a t-25 loosen it then push it in to remove the plate from the bumper cover.Then remove the black molding that is on the bumper.There is screws behind the black molding.Then to will need to remove the clips from the top of the cover under the hood.Push the center down easy till you feel a click then they should come out.Be careful they break sometimes.
Then you can access the screws for the headlight.
