Greetings everyone! I’ve just joined the forum and have enjoyed reading through the questions and answers posted here about V 70s.
I live in Cody, Wyoming and bought my 2001 V70 T5 new from a dealership in Billings, Montana, a two-hour drive away. I’ve thoroughly enjoyed the car and have taken good care of it. It has about 92K miles on it and has received all scheduled and recommended maintenance including changing the timing belt at 80K, and so on.
I decided to have it painted back to its original black color by a local body and repair shop known for their top-notch work. I also asked them to repair the passenger side front window which would only go down about half-an-inch. I got the car back at the end of January. The paint job was wonderful. But the window didn’t work properly and still does not. I don’t know if all the stuff I’ve observed since January related, or not. So, I’ll summarize what’s gone on with the window issue for your consideration. Note: when I say the window ‘doesn’t work’, I mean that it doesn’t respond properly to either of the arm rest control buttons.
I don’t think the repair shop is trying to rip me of or anything like that. In fact, I feel that they’re working hard to figure out what’s wrong with my car and fix it once and for all. I’m just afraid that my local mechanics don’t have enough experience with my kind of problem to diagnose it accurately. I’m reaching out to you folks and hoping for some helpful insight.
So, have you folks ever heard of a problem like this? Any suggestions about how I should proceed?
I’m planning to let the local guys do what they can for the time being and hope they can fix the problem. The next option for me is to take it to the dealer in Billings for their sole, certified Volvo mechanic to diagnose it.
Thanks in advance,
V70WY
- For the maybe ten days, the window worked fine.
- It started sticking again and I took it back to the shop. They readjusted some stuff in the door and it worked well when I got it back. I put it through brief stress tests (jerking it up and down with the buttons) to see if it would fail again, and it didn’t.
- A couple of weeks later, the window developed an intermittent failure. I noticed that there was a correlation between the digital dash thermometer (located just under the clock) displaying only dashes that looked like { --:-- } and the window not working. I’d start the car and the thermometer would show the dashes and the window wouldn’t work. I’d drive for, say, 10 or 15 minutes, and notice the thermometer was reading somewhere in the 35°-45°F range and the window would work. Okay, I figured something in the car needed to warm up for a while for the window to work. No big deal – I could live with that since everything else was working.
- The car sat idle for a week. When I tried to start it, the battery (14-months old) was dead. I found that a passenger door was ajar and figured the dome light had drained the battery. After a trickle charge it started right up. Reset the anti-theft stuff with the key and drove it for an hour on a 50°day. The window would not function and thermometer only displayed the dashes. Put the car in the garage and made certain everything about it was turned off and/or closed.
- The battery was dead the next day. Charged it, drove the car (window and thermostat not working), garaged it.
- The following morning, my wife said she’d noticed the car’s dome light on when she took the trash out the night before. Sure enough, the battery was dead. Charged it, drove it (window and thermostat not working). Got it home and checked for an electrical short circuit by removing the negative cable from the battery and tapping it back on the terminal. It sparked, suggesting to me a short somewhere in the system (I learned this trick from John Muir’s book, How to Keep Your Volkswagen Alive. Hope it holds true for cars younger than my air-cooled, 40-hp, 12-volt, rattle-trap).
- Called the shop and told them about the early correlation between the bad clock display and the window not working and how it got worse with time and then constant. Also how both of those things used to work when things got warmer. l Took the car back to the shop and repeated the stuff about the clock and the window and also told them about the frequent battery drains and the possible electrical short.
- The door hardware turned out to be working properly. They ran diagnostics on something located somewhere and determined that the ‘module’ that controls the window had failed and OEM replacement part is ‘obsolete’. I authorized ordering a used one.
- They put the used module in last Thursday and it didn’t solve the problem. They’re gonna pull it and test it. If it fails, they’ll get another and will try again.
Thanks in advance,
V70WY
