1 - 11 of 11 Posts
The car has plenty of freon and no leaks. I put in a new climat control panel. Relay tested good. At this point there's no signal to the relay from the ecm. Is there a way to test the ecm or where do I go from here?
What about the high pressure switch?
If you have power to the low pressure switch is should work.The low pressure switch is on the end of the circuit.What about the sensor on the compressor?
If you have power at the low pressure switch then you should have power at the compressor.
There is a sensor that screws into the back of the compressor.Follow the wire for the compressor.Then you should find it you can elliminate the sensor and plug straight to the compressor.
Do you have power at the compressor?
Discussion Starter · #9 ·
Ok, did some more checking and turns out i'm not getting power to the low pressure switch. Where does this thing get it's power from? I read in the wiring diagram that it gets it's power from the control panel on the dash. is this correct?
1 - 11 of 11 Posts
